Fumo (sfiato ?) sotto motore
9 Anni 2 Settimane fa #141135 da Zappa
Risposta da Zappa al topic Fumo (sfiato ?) sotto motore
grazie CaravelleC
Caravelle GL TD1600 diy Camper '86 | Honda cb 400 ss '75 | Vespa 50 L '66 | Vespa Px 150 '01
Tempo creazione pagina: 0.280 secondi
Settings50.555MBMemory Usage759msRequest Duration
Theme
Open Button Position
Hide Empty Tabs
Autoshow
Reset to defaults
Joomla! Version5.3.0
PHP Version8.2.28
Identityguest
Response200
Templateja_purity_iv
Database
Server
mysql
Version
8.0.42
Collation
utf8mb4_0900_ai_ci
Conn Collation
utf8mb4_0900_ai_ci
$_GET
array:1 [ "start" => "15" ]
$_POST
$_SESSION
array:1 [ "joomla" => "***redacted***" ]
$_COOKIE
$_SERVER
array:58 [ "CONTEXT_DOCUMENT_ROOT" => "/home/c0100385/public_html" "CONTEXT_PREFIX" => "" "DOC...
session
array:3 [ "counter" => 1 "timer" => array:3 [ "start" => 1747435543 "last" => 1747435543...
registry
array:3 [ "data" => array:1 [ "com_kunena" => array:2 [ "user0_read" => array:25 [ ...
user
array:21 [ "id" => 0 "name" => null "username" => null "email" => null "password" => "***r...
plg_system_languagefilter
array:1 [ "language" => "it-IT" ]
plg_system_webauthn
array:1 [ "returnUrl" => "https://mail.jokeristi.it/index.php/forum/motore-diesel-e-td/9111-fumo-s...
  • afterLoad (3.66MB) (31.83ms)
  • afterInitialise (12.56MB) (139ms)
  • afterRoute (1.61MB) (28.66ms)
  • beforeRenderComponent com_kunena (403.35KB) (5.03ms)
  • Before Access::preloadComponents (all components) (4.75MB) (133ms)
  • After Access::preloadComponents (all components) (130.23KB) (1.56ms)
  • Before Access::getAssetRules (id:863 name:com_kunena) (56B) (28μs)
  • After Access::getAssetRules (id:863 name:com_kunena) (24.85KB) (437μs)
  • afterRenderComponent com_kunena (7.21MB) (146ms)
  • afterDispatch (264.17KB) (3.63ms)
  • beforeRenderRawModule mod_cblogin (Login) (1.5MB) (33.21ms)
  • afterRenderRawModule mod_cblogin (Login) (9.1MB) (85.36ms)
  • beforeRenderModule mod_cblogin (Login) (704B) (19μs)
  • afterRenderModule mod_cblogin (Login) (26.65KB) (734μs)
  • beforeRenderRawModule mod_menu (Main Menu) (7.63KB) (45μs)
  • afterRenderRawModule mod_menu (Main Menu) (606.11KB) (9.19ms)
  • beforeRenderModule mod_menu (Main Menu) (704B) (9μs)
  • afterRenderModule mod_menu (Main Menu) (13KB) (392μs)
  • beforeRenderRawModule mod_menu (mainmenu) (405.55KB) (3.39ms)
  • afterRenderRawModule mod_menu (mainmenu) (433.39KB) (6.11ms)
  • beforeRenderModule mod_menu (mainmenu) (704B) (9μs)
  • afterRenderModule mod_menu (mainmenu) (15.63KB) (324μs)
  • afterRender (6.13MB) (129ms)
  • 1 x afterRenderComponent com_kunena (7.21MB) (19.28%)
    146ms
    1 x afterInitialise (12.56MB) (18.33%)
    139ms
    1 x Before Access::preloadComponents (all components) (4.75MB) (17.54%)
    133ms
    1 x afterRender (6.13MB) (17.03%)
    129ms
    1 x afterRenderRawModule mod_cblogin (Login) (9.1MB) (11.25%)
    85.36ms
    1 x beforeRenderRawModule mod_cblogin (Login) (1.5MB) (4.38%)
    33.21ms
    1 x afterLoad (3.66MB) (4.19%)
    31.83ms
    1 x afterRoute (1.61MB) (3.78%)
    28.66ms
    1 x afterRenderRawModule mod_menu (Main Menu) (606.11KB) (1.21%)
    9.19ms
    1 x afterRenderRawModule mod_menu (mainmenu) (433.39KB) (0.8%)
    6.11ms
    1 x beforeRenderComponent com_kunena (403.35KB) (0.66%)
    5.03ms
    1 x afterDispatch (264.17KB) (0.48%)
    3.63ms
    1 x beforeRenderRawModule mod_menu (mainmenu) (405.55KB) (0.45%)
    3.39ms
    1 x After Access::preloadComponents (all components) (130.23KB) (0.21%)
    1.56ms
    1 x afterRenderModule mod_cblogin (Login) (26.65KB) (0.1%)
    734μs
    1 x After Access::getAssetRules (id:863 name:com_kunena) (24.85KB) (0.06%)
    437μs
    1 x afterRenderModule mod_menu (Main Menu) (13KB) (0.05%)
    392μs
    1 x afterRenderModule mod_menu (mainmenu) (15.63KB) (0.04%)
    324μs
    1 x beforeRenderRawModule mod_menu (Main Menu) (7.63KB) (0.01%)
    45μs
    1 x Before Access::getAssetRules (id:863 name:com_kunena) (56B) (0%)
    28μs
    1 x beforeRenderModule mod_cblogin (Login) (704B) (0%)
    19μs
    1 x beforeRenderModule mod_menu (Main Menu) (704B) (0%)
    9μs
    1 x beforeRenderModule mod_menu (mainmenu) (704B) (0%)
    9μs
119 statements were executed, 14 of which were duplicates, 105 unique62.81ms433.13KB
  • SELECT @@SESSION.sql_mode;164μs968B/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:259Copy
  • SELECT `data` FROM `joom1_session` WHERE `session_id` = ?291μs1008BParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:250Copy
  • SELECT `session_id` FROM `joom1_session` WHERE `session_id` = :session_id LIMIT 1146μs1.3KBParams/libraries/src/Session/MetadataManager.php:187Copy
  • INSERT INTO `joom1_session` (`session_id`,`guest`,`time`,`userid`,`username`,`client_id`) VALUES (:session_id, :guest, :time, :user_id, :username, :client_id)5.96ms944BParams/libraries/src/Session/MetadataManager.php:260Copy
  • SELECT `extension_id` AS `id`,`element` AS `option`,`params`,`enabled` FROM `joom1_extensions` WHERE `type` = 'component' AND `state` = 0 AND `enabled` = 11.07ms33.73KB/libraries/src/Component/ComponentHelper.php:399Copy
  • SELECT `id`,`rules` FROM `joom1_viewlevels`203μs672B/libraries/src/Access/Access.php:955Copy
  • SELECT `b`.`id` FROM `joom1_usergroups` AS `a` LEFT JOIN `joom1_usergroups` AS `b` ON `b`.`lft` <= `a`.`lft` AND `b`.`rgt` >= `a`.`rgt` WHERE `a`.`id` = :guest324μs1.33KBParams/libraries/src/Access/Access.php:868Copy
  • SELECT `folder` AS `type`,`element` AS `name`,`params` AS `params`,`extension_id` AS `id` FROM `joom1_extensions` WHERE `enabled` = 1 AND `type` = 'plugin' AND `state` IN (0,1) AND `access` IN (:preparedArray1,:preparedArray2) ORDER BY `ordering`1.71ms20.48KBParams/libraries/src/Plugin/PluginHelper.php:294Copy
  • SELECT `value` FROM `joom1_admintools_storage` WHERE `key` = 'cparams'239μs1.15KB/administrator/components/com_admintools/src/Helper/Storage.php:120Copy
  • SELECT * FROM `joom1_languages` WHERE `published` = 1 ORDER BY `ordering` ASC254μs1.66KB/libraries/src/Language/LanguageHelper.php:179Copy
  • SELECT `option`,`view`,`query` FROM `joom1_admintools_wafexceptions`150μs640B/plugins/system/admintools/src/Utility/Cache.php:196Copy
  • SELECT `params` FROM `joom1_extensions` WHERE `type` = 'plugin' AND `folder` = 'system' AND `element` = 'admintools'301μs536B/plugins/system/admintools/src/Utility/RescueUrl.php:324Copy
  • SELECT * FROM `joom1_kunena_configuration` WHERE `id` = 1193μs592B/libraries/kunena/src/Config/KunenaConfig.php:1711Copy
  • SELECT sampleData FROM joom1_kunena_version ORDER BY id DESC LIMIT 1163μs536B/libraries/kunena/src/Forum/KunenaForum.php:374Copy
  • SELECT `element`,`name`,`client_id`,`extension_id` FROM `joom1_extensions` WHERE `type` = 'language' AND `state` = 0 AND `enabled` = 1298μs848B/libraries/src/Language/LanguageHelper.php:252Copy
  • SELECT `params` FROM `joom1_extensions` WHERE `type` = 'plugin' AND `folder` = 'system' AND `element` = 'admintools'224μs536B/plugins/system/admintools/src/Utility/RescueUrl.php:324Copy
  • SELECT * FROM `joom1_admintools_ipautoban`186μs1.94KB/plugins/system/admintools/src/Utility/Cache.php:126Copy
  • SELECT `ip` FROM `joom1_admintools_ipblock`134μs568B/plugins/system/admintools/src/Utility/Cache.php:136Copy
  • SELECT * FROM `joom1_admintools_storage` WHERE `key` LIKE 'timestamp_%'205μs608B/plugins/system/admintools/src/Feature/Base.php:253Copy
  • SELECT `source`,`dest`,`keepurlparams` FROM `joom1_admintools_redirects` WHERE `published` = 1 ORDER BY `ordering` ASC168μs640B/plugins/system/admintools/src/Utility/Cache.php:162Copy
  • SELECT `template` FROM `joom1_template_styles` WHERE `client_id` = 0 AND `home` = 1265μs536B/plugins/system/helix3/helix3.php:247Copy
  • SELECT * FROM joom1_menu WHERE alias ='forum' AND published=1318μs2.84KB/plugins/system/t4/src/t4/MVC/Router/T4.php:352Copy
  • SELECT `m`.`id`,`m`.`menutype`,`m`.`title`,`m`.`alias`,`m`.`note`,`m`.`link`,`m`.`type`,`m`.`level`,`m`.`language`,`m`.`browserNav`,`m`.`access`,`m`.`params`,`m`.`home`,`m`.`img`,`m`.`template_style_id`,`m`.`component_id`,`m`.`parent_id`,`m`.`path` AS `route`,`e`.`element` AS `component` FROM `joom1_menu` AS `m` LEFT JOIN `joom1_extensions` AS `e` ON `m`.`component_id` = `e`.`extension_id` WHERE ( (`m`.`published` = 1 AND `m`.`parent_id` > 0 AND `m`.`client_id` = 0) AND (`m`.`publish_up` IS NULL OR `m`.`publish_up` <= :currentDate1)) AND (`m`.`publish_down` IS NULL OR `m`.`publish_down` >= :currentDate2) ORDER BY `m`.`lft`1ms35.92KBParams/libraries/src/Menu/SiteMenu.php:166Copy
  • SELECT * FROM `joom1_kunena_aliases` WHERE `alias` LIKE 'motore-diesel-e-td%'251μs704B/libraries/kunena/src/Route/KunenaRoute.php:800Copy
  • SELECT `option`,`view`,`task`,`query`,`query_type`,`query_content`,`verb`,`application` FROM `joom1_admintools_wafblacklists` WHERE `enabled` = 1212μs976B/plugins/system/admintools/src/Utility/Cache.php:182Copy
  • SELECT `word` FROM `joom1_admintools_badwords`159μs520B/plugins/system/admintools/src/Utility/Cache.php:116Copy
  • SELECT `id`,`home`,`template`,`s`.`params`,`inheritable`,`parent` FROM `joom1_template_styles` AS `s` LEFT JOIN `joom1_extensions` AS `e` ON `e`.`element` = `s`.`template` AND `e`.`type` = 'template' AND `e`.`client_id` = `s`.`client_id` WHERE `s`.`client_id` = 0 AND `e`.`enabled` = 1379μs16.83KB/administrator/components/com_templates/src/Model/StyleModel.php:718Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'176μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SHOW FULL TABLES WHERE table_type="BASE TABLE"3.36ms4.56KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:587Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_sessions`859μs1.34KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_users`1.09ms1.77KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `joom1_assets` WHERE `name` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4,:preparedArray5,:preparedArray6,:preparedArray7,:preparedArray8,:preparedArray9,:preparedArray10,:preparedArray11,:preparedArray12,:preparedArray13,:preparedArray14,:preparedArray15,:preparedArray16,:preparedArray17,:preparedArray18,:preparedArray19,:preparedArray20,:preparedArray21,:preparedArray22,:preparedArray23,:preparedArray24,:preparedArray25,:preparedArray26,:preparedArray27,:preparedArray28,:preparedArray29,:preparedArray30,:preparedArray31,:preparedArray32,:preparedArray33,:preparedArray34,:preparedArray35,:preparedArray36,:preparedArray37,:preparedArray38,:preparedArray39,:preparedArray40,:preparedArray41,:preparedArray42,:preparedArray43,:preparedArray44,:preparedArray45,:preparedArray46)788μs7.81KBParams/libraries/src/Access/Access.php:357Copy
  • SELECT DISTINCT(user_id) FROM `joom1_usergroups` AS `ug1` INNER JOIN `joom1_usergroups` AS `ug2` ON ug2.lft >= ug1.lft AND ug1.rgt >= ug2.rgt INNER JOIN `joom1_user_usergroup_map` AS `m` ON ug2.id = m.group_id WHERE ug1.id IN ( 8)2.02ms3.09KB/plugins/kunena/joomla/KunenaAccessJoomla.php:388Copy
  • SELECT DISTINCT(user_id) FROM `joom1_usergroups` AS `ug1` INNER JOIN `joom1_usergroups` AS `ug2` ON ug2.lft >= ug1.lft AND ug1.rgt >= ug2.rgt INNER JOIN `joom1_user_usergroup_map` AS `m` ON ug2.id = m.group_id WHERE ug1.id IN ( 7)1.54ms584B/plugins/kunena/joomla/KunenaAccessJoomla.php:388Copy
  • SELECT `user_id`,`category_id`,`role` FROM `joom1_kunena_user_categories` WHERE `role` IN (1,2)210μs656B/libraries/kunena/src/Access/KunenaAccess.php:168Copy
  • SELECT * FROM `joom1_kunena_categories` ORDER BY `ordering`,`name`778μs21.39KB/libraries/kunena/src/Forum/Category/KunenaCategoryHelper.php:101Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_categories`1.32ms1.89KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '67'270μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '55'239μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '66'207μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '52'209μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '75'204μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '53'203μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '65'214μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '57'202μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '64'220μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '50'203μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '70'206μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '56'202μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '68'212μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '51'221μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '49'202μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '63'214μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '71'214μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '54'209μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '96'202μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '95'207μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '80'221μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '84'229μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '85'208μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '76'222μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '83'207μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '69'221μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '78'213μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '81'232μs15.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '82'211μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '87'230μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '59'260μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '77'222μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '86'211μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '88'205μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '79'211μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '94'208μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '89'209μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '90'212μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '91'206μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '92'211μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SELECT * FROM `joom1_kunena_categories` WHERE `id` = '93'209μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_topics`1.05ms1.7KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT * FROM `joom1_kunena_topics` WHERE `id` = '9111'231μs2.81KB/libraries/kunena/src/Tables/TableKunenaTopics.php:223Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_messages`871μs1.58KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT m.*,t.message FROM `joom1_kunena_messages` AS `m` INNER JOIN `joom1_kunena_messages_text` AS `t` ON `m`.`id` = `t`.`mesid` WHERE `m`.`id` = 140001301μs2.53KB/libraries/kunena/src/Tables/TableKunenaMessages.php:216Copy
  • SELECT COUNT(*) FROM `joom1_kunena_messages` AS `a` WHERE `thread` = '9111' AND `a`.`hold` IN (0)399μs536B/libraries/kunena/src/Database/Finder/KunenaFinder.php:278Copy
  • SELECT a.id FROM `joom1_kunena_messages` AS `a` WHERE `thread` = '9111' AND `a`.`hold` IN (0) ORDER BY a.`time` ASC LIMIT 18, 6322μs536B/libraries/kunena/src/Database/Finder/KunenaFinder.php:234Copy
  • SELECT m.*, t.message FROM `joom1_kunena_messages` AS `m` INNER JOIN `joom1_kunena_messages_text` AS `t` ON m.id = t.mesid WHERE `m`.`id` IN (141135)240μs2.53KB/libraries/kunena/src/Forum/Message/KunenaMessageHelper.php:120Copy
  • SELECT * FROM `joom1_kunena_thankyou` WHERE `postid` IN (141135)169μs688B/libraries/kunena/src/Forum/Message/Thankyou/KunenaMessageThankyouHelper.php:116Copy
  • SELECT u.name, u.username, u.email, u.block AS blocked, u.registerDate, u.lastvisitDate, ku.*, u.id AS userid FROM `joom1_users` AS `u` LEFT JOIN `joom1_kunena_users` AS `ku` ON `u`.`id` = `ku`.`userid` WHERE `u`.`id` IN (3237)347μs4.63KB/libraries/kunena/src/User/KunenaUserHelper.php:250Copy
  • SELECT * FROM `joom1_kunena_attachments` WHERE `mesid` IN (141135)190μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234Copy
  • SELECT * FROM `joom1_kunena_user_topics` WHERE (`user_id` = '0') AND (`topic_id` IN (9111))181μs1.27KB/libraries/kunena/src/Forum/Topic/User/KunenaTopicUserHelper.php:159Copy
  • SHOW FULL COLUMNS FROM `joom1_kunena_user_topics`706μs1.42KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT `code`,`location` FROM `joom1_kunena_smileys`542μs1.81KB/libraries/kunena/src/BBCode/KunenaBBCode.php:1130Copy
  • UPDATE `joom1_kunena_topics` SET `hits` = (`hits` + 1) WHERE `id` = '9111'310μs48B/libraries/src/Table/Table.php:1348Copy
  • SELECT `m`.`id`,`m`.`title`,`m`.`module`,`m`.`position`,`m`.`content`,`m`.`showtitle`,`m`.`params`,`mm`.`menuid` FROM `joom1_modules` AS `m` LEFT JOIN `joom1_modules_menu` AS `mm` ON `mm`.`moduleid` = `m`.`id` LEFT JOIN `joom1_extensions` AS `e` ON `e`.`element` = `m`.`module` AND `e`.`client_id` = `m`.`client_id` WHERE ( ( (`m`.`published` = 1 AND `e`.`enabled` = 1 AND `m`.`client_id` = :clientId AND `m`.`access` IN (:preparedArray1,:preparedArray2)) AND (`m`.`publish_up` IS NULL OR `m`.`publish_up` <= :publishUp)) AND (`m`.`publish_down` IS NULL OR `m`.`publish_down` >= :publishDown)) AND (`mm`.`menuid` = :itemId OR `mm`.`menuid` <= 0) AND `m`.`language` IN (:preparedArray3,:preparedArray4) ORDER BY `m`.`position`,`m`.`ordering`915μs1.83KBParams/libraries/src/Cache/Controller/CallbackController.php:51Copy
  • SELECT * FROM `joom1_kunena_ranks`224μs912B/libraries/kunena/src/User/KunenaUser.php:1479Copy
  • SELECT userid, MAX(time) AS time FROM `joom1_session` WHERE `client_id` = 0 AND `userid` > 0 AND `time` > '1747433743' GROUP BY `userid` ORDER BY `time` DESC409μs592B/libraries/kunena/src/User/KunenaUserHelper.php:547Copy
  • SELECT * FROM `joom1_kunena_attachments` WHERE `mesid` IN (141135)184μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234Copy
  • SELECT * FROM `joom1_kunena_attachments` WHERE `mesid` IN (141135)150μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234Copy
  • SELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required, a.only_use_in_subform,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note FROM joom1_fields AS a LEFT JOIN `joom1_languages` AS l ON l.lang_code = a.language LEFT JOIN joom1_users AS uc ON uc.id=a.checked_out LEFT JOIN joom1_viewlevels AS ag ON ag.id = a.access LEFT JOIN joom1_users AS ua ON ua.id = a.created_user_id LEFT JOIN joom1_fields_groups AS g ON g.id = a.group_id WHERE ( (`a`.`context` = :context AND `a`.`access` IN (:preparedArray1,:preparedArray2)) AND (`a`.`group_id` = 0 OR `g`.`access` IN (:preparedArray3,:preparedArray4)) AND `a`.`state` = :state) AND (`a`.`group_id` = 0 OR `g`.`state` = :gstate) AND `a`.`only_use_in_subform` = :only_use_in_subform ORDER BY a.ordering ASC764μs4.06KBParams/libraries/src/MVC/Model/BaseDatabaseModel.php:164Copy
  • SELECT * FROM `joom1_kunena_announcement` WHERE `published` = 1 AND (`publish_up` = '1000-01-01 00:00:00' OR `publish_up` <= '2025-05-16 22:45:43') AND (`publish_down` ='1000-01-01 00:00:00' OR `publish_down` >= '2025-05-16 22:45:43') ORDER BY `id` DESC LIMIT 1223μs1.42KB/libraries/kunena/src/Forum/Announcement/KunenaAnnouncementHelper.php:145Copy
  • SELECT `language`,`id` FROM `joom1_menu` WHERE `home` = '1' AND `published` = 1 AND `client_id` = 0376μs592B/libraries/src/Language/Multilanguage.php:123Copy
  • SELECT `params` FROM `joom1_comprofiler_plugin` WHERE `id` = 1258μs536BCopy
  • SELECT *, CONCAT_WS( "/", `folder`, `element` ) AS lookup FROM `joom1_comprofiler_plugin` WHERE `published` = 1 AND `viewaccesslevel` IN (1,5) AND `type` = 'user' ORDER BY `ordering`458μs1.73KBCopy
  • SHOW FULL COLUMNS FROM `joom1_users`1.17ms1.58KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539Copy
  • SELECT f.* FROM joom1_comprofiler_fields f INNER JOIN joom1_comprofiler_tabs AS t ON (f.tabid = t.tabid) WHERE f.published = 1 ORDER BY t.position, t.ordering, f.ordering618μs3.36KBCopy
  • SELECT `id` FROM `joom1_menu` WHERE ( `link` = 'index.php?option=com_comprofiler&view=userprofile' OR `link` = 'index.php?option=com_comprofiler&task=userprofile' OR `link` = 'index.php?option=com_comprofiler' ) AND `published` = 1 AND `access` IN ( 1,5 ) AND `language` IN ( 'it-IT', '*', '' ) AND `client_id` = 0468μs536BCopy
  • SELECT `id` FROM `joom1_menu` WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=login%' OR `link` LIKE 'index.php?option=com_comprofiler&task=login%' ) AND `published` = 1 AND `access` IN ( 1,5 ) AND `language` IN ( 'it-IT', '*', '' ) AND `client_id` = 0401μs536BCopy
  • SELECT `id` FROM `joom1_menu` WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=lostpassword%' OR `link` LIKE 'index.php?option=com_comprofiler&task=lostpassword%' ) AND `published` = 1 AND `access` IN ( 1,5 ) AND `language` IN ( 'it-IT', '*', '' ) AND `client_id` = 0367μs536BCopy
  • SELECT `id` FROM `joom1_menu` WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=registers%' OR `link` LIKE 'index.php?option=com_comprofiler&task=registers%' ) AND `published` = 1 AND `access` IN ( 1,5 ) AND `language` IN ( 'it-IT', '*', '' ) AND `client_id` = 0378μs536BCopy
  • SELECT `value` FROM `joom1_admintools_storage` WHERE `key` = 'criticalfiles'285μs536B/plugins/system/admintools/src/Feature/CriticalFilesMonitoring.php:188Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'206μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SHOW FULL TABLES WHERE table_type="BASE TABLE"2.11ms4.56KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:587Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'192μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'189μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'165μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'155μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SELECT * FROM `joom1_template_styles` WHERE `client_id` = 0 AND `id` = '24'193μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54Copy
  • SELECT SUM(CASE WHEN `a`.`next_execution` <= :now THEN 1 ELSE 0 END) AS due_count,SUM(CASE WHEN `a`.`locked` IS NULL THEN 0 ELSE 1 END) AS locked_count FROM `joom1_scheduler_tasks` AS `a` WHERE `a`.`state` = 1334μs1.37KBParams/administrator/components/com_scheduler/src/Model/TasksModel.php:517Copy
  • SELECT `session_id` FROM `joom1_session` WHERE `session_id` = ?292μs1KBParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:277Copy
  • UPDATE `joom1_session` SET `data` = ? , `time` = ? WHERE `session_id` = ?9.54ms592BParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:301Copy
