Joomla! Version | 5.3.0 |
PHP Version | 8.2.28 |
Identity | guest |
Response | 200 |
Template | ja_purity_iv |
Database |
1 x afterRenderComponent com_kunena (7.29MB) (20.37%) | 159ms |
1 x afterRender (6.16MB) (19.71%) | 154ms |
1 x afterInitialise (12.55MB) (17.43%) | 136ms |
1 x Before Access::preloadComponents (all components) (4.75MB) (16.92%) | 132ms |
1 x afterRenderRawModule mod_cblogin (Login) (9.1MB) (10.34%) | 80.49ms |
1 x beforeRenderRawModule mod_cblogin (Login) (1.5MB) (4.06%) | 31.65ms |
1 x afterLoad (3.66MB) (3.77%) | 29.36ms |
1 x afterRoute (1.61MB) (3.49%) | 27.20ms |
1 x afterRenderRawModule mod_menu (Main Menu) (670.11KB) (1.14%) | 8.91ms |
1 x afterRenderRawModule mod_menu (mainmenu) (433.39KB) (0.76%) | 5.95ms |
1 x beforeRenderComponent com_kunena (403.35KB) (0.62%) | 4.86ms |
1 x afterDispatch (262.92KB) (0.41%) | 3.18ms |
1 x beforeRenderRawModule mod_menu (mainmenu) (341.23KB) (0.41%) | 3.17ms |
1 x After Access::preloadComponents (all components) (130.23KB) (0.17%) | 1.34ms |
1 x afterRenderModule mod_cblogin (Login) (26.65KB) (0.09%) | 730μs |
1 x After Access::getAssetRules (id:863 name:com_kunena) (24.85KB) (0.05%) | 387μs |
1 x afterRenderModule mod_menu (Main Menu) (13KB) (0.04%) | 306μs |
1 x afterRenderModule mod_menu (mainmenu) (15.63KB) (0.04%) | 305μs |
1 x beforeRenderRawModule mod_menu (Main Menu) (7.63KB) (0.01%) | 48μs |
1 x Before Access::getAssetRules (id:863 name:com_kunena) (56B) (0%) | 28μs |
1 x beforeRenderModule mod_cblogin (Login) (704B) (0%) | 15μs |
1 x beforeRenderModule mod_menu (mainmenu) (704B) (0%) | 9μs |
1 x beforeRenderModule mod_menu (Main Menu) (704B) (0%) | 8μs |
SELECT @@SESSION.sql_mode;
136μs968B/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:259CopySELECT `data`
FROM `joom1_session`
WHERE `session_id` = ?
207μs1008BParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:250CopySELECT `session_id`
WHERE `session_id` = :session_id LIMIT 1
144μs1.3KBParams/libraries/src/Session/MetadataManager.php:187CopyINSERT INTO `joom1_session`
(`session_id`,`guest`,`time`,`userid`,`username`,`client_id`) VALUES
(:session_id, :guest, :time, :user_id, :username, :client_id)
5.54ms944BParams/libraries/src/Session/MetadataManager.php:260CopySELECT `extension_id` AS `id`,`element` AS `option`,`params`,`enabled`
FROM `joom1_extensions`
WHERE `type` = 'component' AND `state` = 0 AND `enabled` = 1
549μs33.73KB/libraries/src/Component/ComponentHelper.php:399CopySELECT `id`,`rules`
FROM `joom1_viewlevels`
179μs672B/libraries/src/Access/Access.php:955CopySELECT `b`.`id`
FROM `joom1_usergroups` AS `a`
LEFT JOIN `joom1_usergroups` AS `b` ON `b`.`lft` <= `a`.`lft` AND `b`.`rgt` >= `a`.`rgt`
WHERE `a`.`id` = :guest
283μs1.33KBParams/libraries/src/Access/Access.php:868CopySELECT `folder` AS `type`,`element` AS `name`,`params` AS `params`,`extension_id` AS `id`
WHERE `enabled` = 1 AND `type` = 'plugin' AND `state` IN (0,1) AND `access` IN (:preparedArray1,:preparedArray2)
ORDER BY `ordering`
1.02ms20.48KBParams/libraries/src/Plugin/PluginHelper.php:294CopySELECT `value`
FROM `joom1_admintools_storage`
WHERE `key` = 'cparams'
180μs1.15KB/administrator/components/com_admintools/src/Helper/Storage.php:120CopySELECT *
FROM `joom1_languages`
WHERE `published` = 1
ORDER BY `ordering` ASC
206μs1.66KB/libraries/src/Language/LanguageHelper.php:179CopySELECT `option`,`view`,`query`
FROM `joom1_admintools_wafexceptions`
123μs640B/plugins/system/admintools/src/Utility/Cache.php:196CopySELECT `params`
WHERE `type` = 'plugin' AND `folder` = 'system' AND `element` = 'admintools'
237μs536B/plugins/system/admintools/src/Utility/RescueUrl.php:324CopySELECT *
FROM `joom1_kunena_configuration`
WHERE `id` = 1
319μs592B/libraries/kunena/src/Config/KunenaConfig.php:1711CopySELECT sampleData
FROM joom1_kunena_version
ORDER BY id DESC LIMIT 1
164μs536B/libraries/kunena/src/Forum/KunenaForum.php:374CopySELECT `element`,`name`,`client_id`,`extension_id`
WHERE `type` = 'language' AND `state` = 0 AND `enabled` = 1
328μs848B/libraries/src/Language/LanguageHelper.php:252CopySELECT `params`
278μs536B/plugins/system/admintools/src/Utility/RescueUrl.php:324CopySELECT *
FROM `joom1_admintools_ipautoban`
170μs1.89KB/plugins/system/admintools/src/Utility/Cache.php:126CopySELECT `ip`
FROM `joom1_admintools_ipblock`
153μs568B/plugins/system/admintools/src/Utility/Cache.php:136CopySELECT *
WHERE `key` LIKE 'timestamp_%'
238μs608B/plugins/system/admintools/src/Feature/Base.php:253CopySELECT `source`,`dest`,`keepurlparams`
FROM `joom1_admintools_redirects`
194μs640B/plugins/system/admintools/src/Utility/Cache.php:162CopySELECT `template`
FROM `joom1_template_styles`
WHERE `client_id` = 0 AND `home` = 1
247μs536B/plugins/system/helix3/helix3.php:247CopySELECT *
FROM joom1_menu
WHERE alias ='forum' AND published=1
314μs2.84KB/plugins/system/t4/src/t4/MVC/Router/T4.php:352CopySELECT `m`.`id`,`m`.`menutype`,`m`.`title`,`m`.`alias`,`m`.`note`,`m`.`link`,`m`.`type`,`m`.`level`,`m`.`language`,`m`.`browserNav`,`m`.`access`,`m`.`params`,`m`.`home`,`m`.`img`,`m`.`template_style_id`,`m`.`component_id`,`m`.`parent_id`,`m`.`path` AS `route`,`e`.`element` AS `component`
FROM `joom1_menu` AS `m`
LEFT JOIN `joom1_extensions` AS `e` ON `m`.`component_id` = `e`.`extension_id`
WHERE
(`m`.`published` = 1 AND `m`.`parent_id` > 0 AND `m`.`client_id` = 0) AND
(`m`.`publish_up` IS NULL OR `m`.`publish_up` <= :currentDate1)) AND
(`m`.`publish_down` IS NULL OR `m`.`publish_down` >= :currentDate2)
ORDER BY `m`.`lft`
707μs35.92KBParams/libraries/src/Menu/SiteMenu.php:166CopySELECT *
FROM `joom1_kunena_aliases`
WHERE `alias` LIKE 'consigli-per-le-vacanze%'
234μs704B/libraries/kunena/src/Route/KunenaRoute.php:800CopySELECT `option`,`view`,`task`,`query`,`query_type`,`query_content`,`verb`,`application`
FROM `joom1_admintools_wafblacklists`
WHERE `enabled` = 1
179μs976B/plugins/system/admintools/src/Utility/Cache.php:182CopySELECT `word`
FROM `joom1_admintools_badwords`
119μs520B/plugins/system/admintools/src/Utility/Cache.php:116CopySELECT `id`,`home`,`template`,`s`.`params`,`inheritable`,`parent`
FROM `joom1_template_styles` AS `s`
LEFT JOIN `joom1_extensions` AS `e` ON `e`.`element` = `s`.`template` AND `e`.`type` = 'template' AND `e`.`client_id` = `s`.`client_id`
WHERE `s`.`client_id` = 0 AND `e`.`enabled` = 1
351μs16.83KB/administrator/components/com_templates/src/Model/StyleModel.php:718CopySELECT *
WHERE `client_id` = 0 AND `id` = '24'
177μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySHOW FULL TABLES WHERE table_type="BASE TABLE"
2.22ms4.56KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:587CopySHOW FULL COLUMNS FROM `joom1_kunena_sessions`
802μs1.34KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySHOW FULL COLUMNS FROM `joom1_kunena_users`
1.15ms1.77KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT `id`,`name`,`rules`,`parent_id`
FROM `joom1_assets`
WHERE `name` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4,:preparedArray5,:preparedArray6,:preparedArray7,:preparedArray8,:preparedArray9,:preparedArray10,:preparedArray11,:preparedArray12,:preparedArray13,:preparedArray14,:preparedArray15,:preparedArray16,:preparedArray17,:preparedArray18,:preparedArray19,:preparedArray20,:preparedArray21,:preparedArray22,:preparedArray23,:preparedArray24,:preparedArray25,:preparedArray26,:preparedArray27,:preparedArray28,:preparedArray29,:preparedArray30,:preparedArray31,:preparedArray32,:preparedArray33,:preparedArray34,:preparedArray35,:preparedArray36,:preparedArray37,:preparedArray38,:preparedArray39,:preparedArray40,:preparedArray41,:preparedArray42,:preparedArray43,:preparedArray44,:preparedArray45,:preparedArray46)
676μs7.81KBParams/libraries/src/Access/Access.php:357CopySELECT DISTINCT(user_id)
FROM `joom1_usergroups` AS `ug1`
INNER JOIN `joom1_usergroups` AS `ug2` ON ug2.lft >= ug1.lft AND ug1.rgt >= ug2.rgt
INNER JOIN `joom1_user_usergroup_map` AS `m` ON ug2.id = m.group_id
WHERE ug1.id IN ( 8)
1.9ms3.09KB/plugins/kunena/joomla/KunenaAccessJoomla.php:388CopySELECT DISTINCT(user_id)
WHERE ug1.id IN ( 7)
1.58ms584B/plugins/kunena/joomla/KunenaAccessJoomla.php:388CopySELECT `user_id`,`category_id`,`role`
FROM `joom1_kunena_user_categories`
WHERE `role` IN (1,2)
187μs656B/libraries/kunena/src/Access/KunenaAccess.php:168CopySELECT *
FROM `joom1_kunena_categories`
ORDER BY `ordering`,`name`
785μs21.39KB/libraries/kunena/src/Forum/Category/KunenaCategoryHelper.php:101CopySHOW FULL COLUMNS FROM `joom1_kunena_categories`
1.28ms1.89KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT *
WHERE `id` = '67'
258μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '55'
232μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '66'
218μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '52'
217μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '75'
222μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '53'
202μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '65'
201μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '57'
WHERE `id` = '64'
WHERE `id` = '50'
WHERE `id` = '70'
206μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '56'
205μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '68'
WHERE `id` = '51'
216μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '49'
WHERE `id` = '63'
215μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '71'
WHERE `id` = '54'
WHERE `id` = '96'
209μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '95'
204μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '80'
211μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '84'
228μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '85'
WHERE `id` = '76'
225μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '83'
WHERE `id` = '69'
WHERE `id` = '78'
WHERE `id` = '81'
218μs15.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '82'
WHERE `id` = '87'
207μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '59'
239μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '77'
220μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '86'
212μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '88'
WHERE `id` = '79'
WHERE `id` = '94'
WHERE `id` = '89'
275μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '90'
269μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '91'
296μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '92'
314μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySELECT *
WHERE `id` = '93'
317μs4.66KB/libraries/kunena/src/Tables/TableKunenaCategories.php:295CopySHOW FULL COLUMNS FROM `joom1_kunena_topics`
1.18ms1.7KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT *
WHERE `id` = '3136'
325μs2.81KB/libraries/kunena/src/Tables/TableKunenaTopics.php:223CopySHOW FULL COLUMNS FROM `joom1_kunena_messages`
927μs1.58KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT m.*,t.message
FROM `joom1_kunena_messages` AS `m`
INNER JOIN `joom1_kunena_messages_text` AS `t` ON `m`.`id` = `t`.`mesid`
WHERE `m`.`id` = 47353
314μs2.53KB/libraries/kunena/src/Tables/TableKunenaMessages.php:216CopySELECT COUNT(*)
FROM `joom1_kunena_messages` AS `a`
WHERE `thread` = '3136' AND `a`.`hold` IN (0)
403μs536B/libraries/kunena/src/Database/Finder/KunenaFinder.php:278CopySELECT a.id
ORDER BY a.`time` ASC LIMIT 18, 6
353μs536B/libraries/kunena/src/Database/Finder/KunenaFinder.php:234CopySELECT m.*, t.message
INNER JOIN `joom1_kunena_messages_text` AS `t` ON m.id = t.mesid
WHERE `m`.`id` IN (92984)
260μs2.53KB/libraries/kunena/src/Forum/Message/KunenaMessageHelper.php:120CopySELECT *
FROM `joom1_kunena_thankyou`
WHERE `postid` IN (92984)
159μs688B/libraries/kunena/src/Forum/Message/Thankyou/KunenaMessageThankyouHelper.php:116CopySELECT u.name, u.username, u.email, u.block AS blocked, u.registerDate, u.lastvisitDate, ku.*, u.id AS userid
FROM `joom1_users` AS `u`
LEFT JOIN `joom1_kunena_users` AS `ku` ON `u`.`id` = `ku`.`userid`
WHERE `u`.`id` IN (2296)
346μs4.63KB/libraries/kunena/src/User/KunenaUserHelper.php:250CopySELECT *
FROM `joom1_kunena_attachments`
WHERE `mesid` IN (92984)
162μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234CopySELECT *
FROM `joom1_kunena_user_topics`
WHERE
(`user_id` = '0') AND
(`topic_id` IN (3136))
148μs1.27KB/libraries/kunena/src/Forum/Topic/User/KunenaTopicUserHelper.php:159CopySHOW FULL COLUMNS FROM `joom1_kunena_user_topics`
742μs1.42KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT u.name, u.username, u.email, u.block as blocked, u.registerDate, u.lastvisitDate, ku.*
WHERE `u`.`id` = '1095'
296μs4.59KB/libraries/kunena/src/Tables/KunenaUsers.php:337CopySELECT `code`,`location`
FROM `joom1_kunena_smileys`
646μs1.81KB/libraries/kunena/src/BBCode/KunenaBBCode.php:1130CopyUPDATE `joom1_kunena_topics`
SET `hits` = (`hits` + 1)
WHERE `id` = '3136'
234μs48B/libraries/src/Table/Table.php:1348CopySELECT `m`.`id`,`m`.`title`,`m`.`module`,`m`.`position`,`m`.`content`,`m`.`showtitle`,`m`.`params`,`mm`.`menuid`
FROM `joom1_modules` AS `m`
LEFT JOIN `joom1_modules_menu` AS `mm` ON `mm`.`moduleid` = `m`.`id`
LEFT JOIN `joom1_extensions` AS `e` ON `e`.`element` = `m`.`module` AND `e`.`client_id` = `m`.`client_id`
WHERE
(`m`.`published` = 1 AND `e`.`enabled` = 1 AND `m`.`client_id` = :clientId AND `m`.`access` IN (:preparedArray1,:preparedArray2)) AND
(`m`.`publish_up` IS NULL OR `m`.`publish_up` <= :publishUp)) AND
(`m`.`publish_down` IS NULL OR `m`.`publish_down` >= :publishDown)) AND
(`mm`.`menuid` = :itemId OR `mm`.`menuid` <= 0) AND `m`.`language` IN (:preparedArray3,:preparedArray4)
ORDER BY `m`.`position`,`m`.`ordering`
753μs1.83KBParams/libraries/src/Cache/Controller/CallbackController.php:51CopySELECT *
FROM `joom1_kunena_ranks`
182μs912B/libraries/kunena/src/User/KunenaUser.php:1479CopySELECT userid, MAX(time) AS time
WHERE `client_id` = 0 AND `userid` > 0 AND `time` > '1747500867'
GROUP BY `userid`
ORDER BY `time` DESC
263μs576B/libraries/kunena/src/User/KunenaUserHelper.php:547CopySELECT *
220μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234CopySELECT *
198μs1.45KB/libraries/kunena/src/Attachment/KunenaAttachmentHelper.php:234CopySELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required, a.only_use_in_subform,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note
FROM joom1_fields AS a
LEFT JOIN `joom1_languages` AS l ON l.lang_code = a.language
LEFT JOIN joom1_users AS uc ON uc.id=a.checked_out
LEFT JOIN joom1_viewlevels AS ag ON ag.id = a.access
LEFT JOIN joom1_users AS ua ON ua.id = a.created_user_id
LEFT JOIN joom1_fields_groups AS g ON g.id = a.group_id
WHERE
(`a`.`context` = :context AND `a`.`access` IN (:preparedArray1,:preparedArray2)) AND
(`a`.`group_id` = 0 OR `g`.`access` IN (:preparedArray3,:preparedArray4)) AND `a`.`state` = :state) AND
(`a`.`group_id` = 0 OR `g`.`state` = :gstate) AND `a`.`only_use_in_subform` = :only_use_in_subform
ORDER BY a.ordering ASC
739μs4.06KBParams/libraries/src/MVC/Model/BaseDatabaseModel.php:164CopySELECT *
FROM `joom1_kunena_announcement`
WHERE `published` = 1 AND (`publish_up` = '1000-01-01 00:00:00' OR `publish_up` <= '2025-05-17 17:24:27') AND (`publish_down` ='1000-01-01 00:00:00' OR `publish_down` >= '2025-05-17 17:24:27')
ORDER BY `id` DESC LIMIT 1
166μs1.42KB/libraries/kunena/src/Forum/Announcement/KunenaAnnouncementHelper.php:145CopySELECT `language`,`id`
FROM `joom1_menu`
WHERE `home` = '1' AND `published` = 1 AND `client_id` = 0
354μs592B/libraries/src/Language/Multilanguage.php:123CopySELECT `params`
FROM `joom1_comprofiler_plugin`
WHERE `id` = 1
210μs536BCopySELECT *, CONCAT_WS( "/", `folder`, `element` ) AS lookup
AND `viewaccesslevel` IN (1,5)
AND `type` = 'user'
ORDER BY `ordering`
404μs1.73KBCopySHOW FULL COLUMNS FROM `joom1_users`
1.13ms1.58KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:539CopySELECT f.* FROM joom1_comprofiler_fields f
INNER JOIN joom1_comprofiler_tabs AS t ON (f.tabid = t.tabid)
WHERE f.published = 1
ORDER BY t.position, t.ordering, f.ordering
546μs3.36KBCopySELECT `id`
FROM `joom1_menu`
WHERE ( `link` = 'index.php?option=com_comprofiler&view=userprofile' OR `link` = 'index.php?option=com_comprofiler&task=userprofile' OR `link` = 'index.php?option=com_comprofiler' )
AND `published` = 1
AND `access` IN ( 1,5 )
AND `language` IN ( 'it-IT', '*', '' )
AND `client_id` = 0
412μs536BCopySELECT `id`
FROM `joom1_menu`
WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=login%' OR `link` LIKE 'index.php?option=com_comprofiler&task=login%' )
AND `published` = 1
AND `client_id` = 0
694μs536BCopySELECT `id`
FROM `joom1_menu`
WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=lostpassword%' OR `link` LIKE 'index.php?option=com_comprofiler&task=lostpassword%' )
AND `published` = 1
AND `client_id` = 0
336μs536BCopySELECT `id`
FROM `joom1_menu`
WHERE ( `link` LIKE 'index.php?option=com_comprofiler&view=registers%' OR `link` LIKE 'index.php?option=com_comprofiler&task=registers%' )
AND `published` = 1
AND `client_id` = 0
341μs536BCopySELECT `value`
WHERE `key` = 'criticalfiles'
160μs536B/plugins/system/admintools/src/Feature/CriticalFilesMonitoring.php:188CopySELECT *
213μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySHOW FULL TABLES WHERE table_type="BASE TABLE"
2.08ms4.56KB/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php:587CopySELECT *
208μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySELECT *
157μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySELECT *
158μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySELECT *
180μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySELECT *
183μs928B/plugins/system/helixultimate/src/Platform/Helper.php:54CopySELECT SUM(CASE WHEN `a`.`next_execution` <= :now THEN 1 ELSE 0 END) AS due_count,SUM(CASE WHEN `a`.`locked` IS NULL THEN 0 ELSE 1 END) AS locked_count
FROM `joom1_scheduler_tasks` AS `a`
WHERE `a`.`state` = 1
249μs1.37KBParams/administrator/components/com_scheduler/src/Model/TasksModel.php:517CopySELECT `session_id`
283μs1KBParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:277CopyUPDATE `joom1_session`
SET `data` = ?
, `time` = ?
8.09ms592BParams/libraries/vendor/joomla/session/src/Handler/DatabaseHandler.php:301Copy
